| Notices |
StangNet.com is 10 years old!
Come on! Help us celebrate this fantastic feat by stopping in and letting us know how StangNet has shaped your experience surrounding the Ford Mustang! |
This THREAD brought to you by... |
What is the normal vacuum reading for a 5.0? -
09-30-06, 02:24 AM
I think that I may have a vaccumm leak after swaping intake/plenum combo. What is the factory vaccuum reading?
thanks,
Ron
Official Member
09-30-06, 08:36 PM
Quote:
thanks,
Ron
A lot of people seem to say that around 15 inches is normal. I tested this on my car today and I got 15-20 inches at idle.
I think if you are 13-20 you are fine, below 13 is a problem
1989 Mustang GT, Red, 5spd
Engine: Thumper Heads, Explorer Intake, BBK 1 5/8th Headers, Mac Offroad X-pipe, Magnaflows, C&L 73MM, FMS 65MM TB, Electric Fan, 3G Alt., A/C Delete, ASP Underdrive, 155LPH Pump.
Suspension/Misc: LRS Subframes, FMS Front LCAs, FMS Quadrant/Adjuster, Pro3i LCAs, Bullitt Suspension Kit, MM Strut Tower Brace, MM C/C Plates, MM Bumpsteer Kit, SN95 5-lug with 03 Cobra Front Brakes.
10-03-06, 08:50 AM
Depends on your cam and TB. Normal stock should be 14-16
1993 LX 5.0 T5 Notch - Twin Turbo -
(2) T04B's, (2) Tial 38mm gates, Vecco FMIC, Hallman Pro MBC, Greddy Type S BOV
Stock shortblock, E7 heads, Comp cam, GT40 intake, 42# injectors
531 RWHP, 557 RWTQ @ 16 psi
217 quarter mile runs and counting
2003 WRX (its blue obviously)
231 AWHP, 229 AWTQ @ 17 psi
Now everyone in the world will know I wanna bang the handicapped.
10-03-06, 09:00 AM
Quote:
My car is bone stock save for a vortech blower, and full exhaust. I see 18-19 inches of vaccum at idle.
when my BOV nipple broke causing a vaccum leak I only seen 11-13... so I would say the 14-16 would be ever so no enough... but thats just me. Maybe it changes with the years 5.0 seeing how ford put slightly different cams in there througout the 5.0 run.
89 GT 5-Speed
Street Challenge 1/4 Combat
Team: Stangnet Underground
Purpose: To gain strength through stangnet member forces and fight the evil Stangnet OG's on the 1320 battle field
Join Us now, or Lose to us for eternity,
10-03-06, 08:08 PM
13-14 is way low for a stock cam. I'd say normal is probably more along the lines of 18-20+.
I myself pull 14-15 inches of vacuum at idle with an F-cam and 1.7 rr's.
1989 lx 5.0 (notch)
TFS Track Heat heads, 1.7 rr's, f303 cam, Megasquirt ecu, twin .60/.48 turbos@8psi, Tremec 3550, 42lb injectors, 255 fuel pump, 24x12x3 intercooler, Edlebrock Performer Intake, Nitto 275 40 17's, 3.27's, AJE Tubular k-member/A-arms, maximum lowers, Ford Uppers, 99 Disc Brake Conversion
Best 1/4: 12.066 @ 123.15 489rwhp/527rwtq
http://videos.streetfire.net/video/3...ea0150d4a0.htm
10-04-06, 12:58 PM
I pull 8-10 with my comp XE276 lol.. and thats at 1100rpm
Official Member
10-04-06, 03:02 PM
how do you check the vac
tf heads
gt-40 intake tubuler
e-303 cam
3.73 gears
70 thottle
80 mm air
255 fuel pump
291 rwhp & 334 torque
10-04-06, 05:52 PM
check out this site---> www.my5oh.com
10-18-06, 05:44 PM
I am carbd but am pulling 18" vacuum at idle. It was only 15" until i adjusted the idle mixture. I am running the "B" cam and a 4180C with a 6.5 power valve, lightest secondary spring Holley has, and the primary is jetted two sizes up and the secondary metering plate is drilled two sizes up.
George
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
