StangSuspension.com is now offering the new BMR Fabrication front A-arms, for 2005-2007 Mustangs.
BMR tubular A-arms are a lightweight alternative to your factory stamped steel arms. These feature CNC machined rear pivot points, heavy duty 1.25" DOM tubing, and new ball joints sourced from Fords OE supplier. Unlike BMR competitors, these A-arms are also compatible with your OE K-member.
The adjustable version is durable enough for street use but we recommend it for drag race and road race applications due to the elevated noise transmission from spherical rod ends. Assembled with QA1 XR series Teflon lined rod ends, this version allows camber and caster adjustment not possible with OE arms. 9.6 lbs. lighter than stock.
Features:
- QA1 rod ends (highest quality)
- Perfect for racing
- 9.6lbs lighter than stock!
Check this link for details
http://www.stangsuspension.com/store...idCategory=162
