This THREAD brought to you by... |
Upgrade from speed density to maf? -
12-05-06, 12:19 PM
I have a 88 lx and the only mod I have done is a slp catback exhaust. I need help, what should my next mod be? I'm considering upgrading to maf or installing headers/h-pipe. What should I do next? Thanks!
Official Member
12-05-06, 03:20 PM
It depends on your future plans. If you plan on keeping it just a bolt on car, you shouldn't need the maf conversion, but if you get into things like heads and a cam, then it will be necessary. Headers will do next to nothing to a stock or mild bolt on car, so I would bother with that. Either a high flow-catted h or x-pipe or off-road h or x-pipe should give you a little power. An off-road mid pipe will also make the car louder. There a couple free mods you should look into such as removing the air silencer in the stock airbox, and bumping the timing. I would also suggest and aftermarket shifter (I like mgw) assuming it's a 5spd. Rearend gears would also help the car out a lot.
'88 LX Hatch: Black.
New combo someday...
Y-pipe to one turbo muffler
The amazing "Tornado Air" fuel saver
'99 Buell X1 Lightning: Black. Screamin' Eagle .536 cams, ported/flowed heads, 44mm CV carb, Forcewinder intake, Force Exhaust.
'91 Honda CR500R: The only thing Chuck Norris is afraid to kick.
'99 Hayabusa: 240rwhp/140rwtq. All motor, dot tire, no wheelie bar. 9.78 @ 155 so far. Need an nhra license  Will go mid 8s @ 160+
12-05-06, 09:53 PM
Honestly make a budget and a real plan on what you want.. I built a 12 second car 5 years ago that was stuck getting modded and barely into the 11's, so i finally sold the whole combo and went for big numbers....If i had it to do again though just for a low 12 high sec drivable car , I would go in this order... Off road H or X pipe, U/D pulleys, Gears, then shorty headers, Then go with Injectors and mass air, An intake, then heads N cam... Just an idea though. Like blackened said there are PLENTY of free mods... Oh and yes... If you do convert to Mass air try to find a donor car.. I bought the FRPP conversion kit and ended up ditching it for a harness...
08 Fusion SE , 3.0 V6 , 18 inch rims, Rear Deck Spoiler, Black and Red Leather. stock.. stock
 8UR LS6 -- 88 GT - 10.5:1 Keith Kraft Forged 306, Fully Ported Edelbrock Perfromer RPM's by Champion Racing Heads, Extrude Honed Cobra Upper and Lower, 30lb injectors, 70 MM T-Body, Bullet 75 MAF, Compucar 150 shot, Full exhaust, , 3.73's, Mickey Thompson 275/50-15 Drag Radials on welds Bigs N Littles, 2 1/2 Cervini's Cowl induction hood, Saleen Wing.
lover of pudgy polygamists
12-05-06, 10:51 PM
You can do any mods you want, just stay away from cams that produce under about 17in of vacuum. My car ran mid 13s spinnin the hell out of the street tires before I converted to mass air, I did actually feel a gain with mass air though and my idle quality got a little better. With that said, I believe that a mass air conversion is a good idea, but its not crucial and theres other things you could spend your money on.
79 Indy 500 Pace Car with roller 5.0 and fuel injection, A9P, 75mm pro-m. #24 injectors, TFS TW heads, ProComp 1.6 RRs, TFS1 cam, Trickflow Track Heat, Pro Products 75mm TB, Accel FPR, CAI, BBK shorties, Off road H pipe, Magnaflow catback, 8.8 rear with 3.55s, T-5, Hurst shifter/steeda handle, Pro3i LCAs, FMS C springs, ROH ZS Racing wheels, 235/45/17 front, 255/45/17 rear.
Modified Mustangs Aug, 2006 Feature Car
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
