Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page Nice New Section + ? on Poly Bushings
Notices
Reply
(#1 (permalink))
Old
Jenns01TA's Avatar
Official Member
Nice New Section + ? on Poly Bushings - 03-26-07, 08:18 PM
Hey fellas!
Nice to see a section for OT Tech. Now that I am a proud owner of a un-Stang - the TA - gotta question.
How many of you have used aftermarket silicon impregnated Polyurethane bushings in vehicels other than the Stangs? If you have, where did you use them and what did you find the positives/negatives to be?
I would have went with Delrin for the UCA, but the budget was tight and opted for Energy Suspension's UCA/LCA kit. We got the UCA bushings in after a bear of a time removing the stock OEM rubber from the sleeve-overs. It was more like a Tire Fire attached to the UCA flaming those compressed mofos out.
Considering a HPDE at PIR mid-summer and would like to use the remaining kit bushings. However, the "Suspension God" I share my life with will not allow such defilement for fear of rebound, binding and bump steer issues relative to the hard compound.
Comments/Questions.....
Thanks All.
~J~
(#2 (permalink))
Old
svttech76's Avatar
SuperMod
it doe snot
03-27-07, 11:42 PM
WOW they made a forum for you to post LS-1 tech
Mike
Ford master service tech
(#3 (permalink))
Old
Jenns01TA's Avatar
Official Member
03-28-07, 10:29 AM
Quote:
hahahahaha.. Better than nude pics, my Friend. Come ON..... No comment from you on the bushings?
(#4 (permalink))
Old
svttech76's Avatar
SuperMod
it doe snot
03-28-07, 08:16 PM
so far you install rear upper and lower control arm bushings right? what else came with the kit..
Mike
(#5 (permalink))
Old
Jenns01TA's Avatar
Official Member
03-28-07, 08:46 PM
No go on the lowers, Bud. And that was a barter swap for favors just to get an allowance on the uppers. The kit came with front UCA/LCA bushings and inner sleeves.
The product literature link is below. A couple of my Stang buddies from the past have used ES Hyper-Flex bushings with little to no problem at track events; however, they were not Auto-X or HPDE runners for that matter. 1/4 mile junkies versus corner carvers.
From what I have read and been advised, standard polyurethane bushings can be harsh and are prone to lateral movement rebound bind; however, it appears that the binding comes under heavy lateral load and cornering. I don't believe I am too harsh in my driving to not put the LCA bushings on as well.
http://www.energysuspension.com/pages/contarm.html
Do you have any data on this rebound/bind phenomenon that is preventing the love of my life and my in-house Suspension Guru from allowing the use of the remainder of the kit, Mike?
It’s not that I do not believe and trust what he say; however, I am a tad butt munched spending hard earned $ on bushings that may not be used. If the data supports the hypothesis, then I will concede. If not, I have one heck of a task ahead of me to convince him to give me the second set of hands needed to perform the LCA bushing swap.
(#6 (permalink))
Old
timeless2's Avatar
My turn.
03-28-07, 08:53 PM
May I ask what your goals are?
Tim
2010 Ford Mustang | MagnaFlow Exhaust | Toy Reviews & Recalls
Life is not about what you take; it is what you leave behind.
(#7 (permalink))
Old
Jenns01TA's Avatar
Official Member
03-29-07, 01:06 PM
My main and immediate goal is to limit wheel hop and the transitional driveline/drivetrain/driveshaft damage associated with it.
This is no joke. The wheel hop regardless of HOW I drive this F-Body is substantial and needs my immediate attention.
(#8 (permalink))
Old
blackfang's Avatar
04-01-07, 07:55 AM
To eliminate wheelhop on your TA, you need Aftermarket LCA's, Panhard rod and get rid of that weak Torque Arm(F-Body's don't have UCA's for the rear). BMR, UMI and Spohn have great kits that do a great job.
Here is a pic of how good a set up can do.
My Site | My photos
2007 Subaru Legacy 2.5i
1997 Cobra- Full Exhaust | Bolt Ons | Suspension & Drivetrain mods | Pro Stars w/ DR's | Tuned by JMS
1998 Z/28 hardtop- Typical LS1 with some bolt ons and exhaust mods.
(#9 (permalink))
Old
Jenns01TA's Avatar
Official Member
04-01-07, 12:27 PM
Thanks Black . I should have IM'd ya' from the get-go.
Interesting to note that the two kits below the TBC-1 kit both contain Poly bushings in lieu of the military compliant spherical.
I am noticing that most these CAs come with poly and with that provided the poly is used on the axle side and not the frame side it is a preferable option for most applications. In fact BMR actually uses Prothane products with their boxed CAs. Your take on this Black?
Quote:
Originally Posted by GlobalWest
Spherical aircraft bearings on the frame side and on the rear-end housing. (double bearing)
Kit Part # TBC-1
"This control arm will work in all applications. It is the best design to use in a third and fourth generation F car. They allow the suspension to pivot without bind and provide zero fore and aft defection."
Consequences: Rear end control you never had before.
1982-2001 Double Bearing both sides, Superior over any other rear control arm .
(Best for all applications)
Part# TBC-1 -- -- Price $319.95
Panhard Rod from GW
Part# PHC-2 polyurethane bushings both ends
Price $69.95
(NOTE: Poly panhard rod in picture shown left, adjustable panhard rod shown right)
Global West's Traclink Kit appears to be a great solution for axial deflection in the rear; however - at about $600 shipped, I will wait on this option.
I don't believe it warrants the cost at this time since all I will be running is Grudge Street Legal Wednesday nights and perhaps an HPDE. I wish I could get the TA set-up before April 13th, I would hit Willow Springs for the Shelby Club event there. Not this year though.
(#10 (permalink))
Old
blackfang's Avatar
04-01-07, 05:01 PM
My MM have the same setup on the Cobra with Poly on the chasis end and the Spherical on the axle end. I have noticed that the rear is much more stable.
I have heard alot of good results and comments about BMR. Have you checked into the Spohn setups?
My Site | My photos
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
