Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page Help me figure out where this disconnected wire goes on my 2002 suburban(pics)
Reply
(#1 (permalink))
Old
squares98's Avatar
Official Member
Help me figure out where this disconnected wire goes on my 2002 suburban(pics) - 03-30-07, 02:38 PM
My check engine light turned on and I found this disconnected wire.
I couldnt find any open female plugs. If you own or work on these things could you please look on your full size 99+ GM truck to see where the wire plug and ground connect I'd appreciate it. Thanks.
2007 Infiniti G35 Sedan
1998 Mustang GT-Sold
(#2 (permalink))
Old
tomustang's Avatar
Banned
03-30-07, 06:08 PM
did you get the codes scanned yet?
is there anything that's not running right?
(#3 (permalink))
Old
Jenns01TA's Avatar
Official Member
03-30-07, 06:30 PM
Check the air cleaner assembly box. Pre-MAF sensor @ throttle body.
(#4 (permalink))
Old
gunmetal5.0's Avatar
Official Member
03-30-07, 06:37 PM
Alternator
T5 swap, EFI to Carb swap, low miles '86 5.0 long block, fresh gaskets. New: Weiand aluminum intake manifold, Holley 600cfm carb, Holley fuel pressure regulator, water pump, battery, starter, starter relay, ignition switch, key cylinder, Accel distributor, Accel cap & rotor, Accel wires, Champion plugs, Edelbrock air cleaner, MSD 6A ignition, Autometer Tacho, speedo cable and gear, black-faced w/ chrome rings Equus Gauges including Fuel, Temp, Ammeter, Oil, Speedometer, all new wiring harness.
(#5 (permalink))
Old
squares98's Avatar
Official Member
03-31-07, 01:53 PM
well that plug goes into the engine hood light and the ground attaches to the hood(kinda obvious once I saw it).
But as fas as the check engine, no codes scanned yet.
The only symptom i feel is when coasting in drive or reverse(less than 5mph) the car feels a little jerky, like the feel of super warped brake rotors,(possibly fuel pump related?) I need to get codes scanned
(#6 (permalink))
Old
timeless2's Avatar
Vi Veri Veniversum Vivus Vici
03-31-07, 06:54 PM
What work was done that made this unplugged wiring apparent?
(#7 (permalink))
Old
tomustang's Avatar
Banned
03-31-07, 07:54 PM
Quote:
Well, we can rule out any cleaning.
Glad it was simple enough to find, squares. I had guessed air cleaner assembly box sensor since the CEL had come on with no indicated driveabilty issues. I had a Ford Explorer that had short length wiring to the ACAB that would pull out everytime I checked the air filter and throw the CEL - annoying.
Nice to know Chevy/GMC still provide an underhood light. A small, yet functional item Ford neglected to add to the S197.
Jenn (damn networked computer).
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
