Quote:
Originally Posted by loud 95
I just purchased a fox maf to slap onto the C&L. The old maf was taken out of my '95GT and put into my '88 Bronco II, which has received a fuel injected 5.0. The truck should run better now, but I haven't fired it up yet. I need to have the rest of the exhaust made. I'll keep you all informed.
I'm not sure I fully understand
Are you taking just the sensor from the 95, and installing it in the C&L for use with your A9P computer?
If so you have the wrong sensor. You need a sensor specific to the A9P computer. The C&L 'calibration' depends on this.
If you are using the 95 sensor in the 95 - 70mm housing, with stock 19lb injectors, and the A9P computer, then this will work.
If you are not using stock 19lb injectors, then the 95 MAF assy. will not work with your computer.
I think some more clarification is needed.
jason
