This THREAD brought to you by... |
optimum intake pipe -
05-01-07, 11:13 AM
Just looking for some opinions on an intake pipe for my car. Currently I have a ProM 75mm mass air sensor, and a 70mm TB. I still have my old intake pipe that was a Mac CAI for speed density. I have the filter directly on the MAF. The pipe is narrower however than the TB and MAF sensor, and actually fits inside both. I've been thinking about a fenderwill intake from BBK, but is this a wider diameter than the Mac? Also considering the C&L trueflow pipe, but this isn't fenderwell. Ideas?
*1986 Mustang GT*
308cid, Trickflow TW Heads, TFS Intake, TFS Stage 1 cam, MAF conversion, Pro-M 75mm mass air, 70mm TB, FMS 24# injectors, BBK longtube headers, Off road h-pipe, flowmasters, 3.55 gears.
05-01-07, 12:03 PM
You need to at least match the TB and intake tube DIA. If air is flowing through a certain DIA and then quickly changes to a bigger DIA you run into a problem called vina contracta which creates a swirling of the air and it inturupts the flow.
Official Member
05-01-07, 05:16 PM
Stock box, remove the silencer, C&L pipe...
That should be pretty decent!
jason
05-01-07, 06:37 PM
jason
What about the mass air sensor? Will that connect to the stock air box?
*1986 Mustang GT*
Official Member
05-02-07, 06:04 AM
Quote:
It *should* hook up just fine.
However, I don't have ANY first hand experience with PMAS meters...
jason
Official Member
05-11-07, 09:54 PM
I would do a C&L from the TB to the MAF sensor then from the MAF sensor use the fender well piece from the mac kit.
Official Member
05-11-07, 10:57 PM
Quote:
He already has a PMAS, so I would think sticking with that would be best...
No reason to downgrade to a C&L meter.
jason
Official Member
06-24-07, 06:58 AM
Jason, I think he's talking about a C&L Trueflow from the MAF to the TB.
I have a new C&L Trueflow sitting here for use on my new combo. The problem I am having is it doesn't come close to fitting. By that I mean that it sticks out so far from the TB that it will hit the strut tower.
'92 5.0 5 spd - 3.73 - Flowmaster American Thunder - MAC Off Road H - FMS Shorties - Stock Short Block - Ported GT-40Ps - B cam - 26# Vette Injectors - MAC MAF - MAC Windage Tray - Explorer Upper And Lower - Ported Explorer TB - March Ram Air - GMS Aluminum Radiator - Dynamic Racing Double Adjustable Uppers - Strange Struts - CE Shocks - Steeda Aluminum LCAs - FRPP "B" Springs - JS Motorsport Sub-frame Connectors
Official Member
06-27-07, 10:15 PM
Im looking at trying the Anderson N/A Power Pipe.
The C&L Fits like crap. And puts the filter right by the alternator and fan.
1993 Coupe Cobra Intake, Pullies, Full Exhaust, C&L 76mm MAF, 70mm TB, TKO 600, CF DF Clutch, Alum. DS, 4.10's, Auburn Pro, 31 Spline Axles, Pro 3i Rear Susp. 99GT front brakes, Taurus Fan, 3G Alt, and tons more.
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
