Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page Need some help: 5.0 Owner...
Notices
Reply
(#1 (permalink))
Old
GreatWhite's Avatar
Official Member
Need some help: 5.0 Owner... - 05-14-07, 12:00 PM
...but my '93 Saturn is having some front end trouble. haha
It seems like the brakes aren't disengaging completely on my right front. In reverse, it will stay locked up and drag until I give it considerable. In drive, it will start spinning but I can hear something rubbing.
After taking the wheel off, I can't see any real distinct grooves being cut into the rotor, but there is ALOT of gunk all over the inside of the wheel as well as behind the caliper.
My brake fluid levels are fine and this just started happening like this week. Any ideas? Thanks for reading.
--GW
FORMALLY: cjman15
(#2 (permalink))
Old
5.0 con-vert's Avatar
No soup for you, Joe Rogan!!!
05-14-07, 12:30 PM
Did you check your ebrake? Maybe it locked into place. You can still drive with it on, it just sucks and ruins your brakes and such. I've had mine lock into place after I set it once and had to tap on it with a hammer to get it loose again. Just a thought.
(#3 (permalink))
Old
85ragtop's Avatar
Deputy Dawg
Man woods surround my office.
05-14-07, 01:26 PM
Thread moved.
Nick
5.0 MOD
Quote:
Originally Posted by DMAN302
ahhh...the sarcasm...the stabbing of the back...God bless stangnet.
Quote:
Originally Posted by srothfuss View Post
I thought of a great reply about "feeling fast" but I deceided that I didn't want the gingerbread man to catch me with any type of ban hammer....
baby
(#4 (permalink))
Old
05-14-07, 10:39 PM
Had that happen on a truck.
Turned out to be a bad rubber brake line.
Pushing the brake pedal puts a lot of force on the fluid and forced it through the
brake line, but it acted like a one way valve and wouldn't release the pressure .
(#5 (permalink))
Old
timeless2's Avatar
My turn.
05-15-07, 06:48 AM
Stuck caliper?
If it's seized, try giving it a good cleansing to see if a "bath" of cleaner helps it move freely. Else, the caliper might just be shot.
Tim
2010 Ford Mustang | MagnaFlow Exhaust | Toy Reviews & Recalls
Life is not about what you take; it is what you leave behind.
(#6 (permalink))
Old
Jenns01TA's Avatar
Official Member
05-15-07, 08:49 PM
Compare how easily the dragging wheel spins compared to the other side by turning it by hand. If it's difficult to turn, loosen the bleeder screw. If the wheel turns freely after relieving the pressure in the caliper, the caliper is alright it is probably the brake hose.
If loosening the bleeder screw does not let the wheel turn freely, check the caliper. It may be a seized piston or the mounting hardware is not allowing the caliper to release the pad (assuming the Saturn uses a typical single piston floating design.) If the thickness of the pads are mismatched (the outer pad is worn more than the inner pad) the caliper hardware is the most likely cause.
If it is none of these it can get real entertaining. Let us know what you find.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
