Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page 97 Expedition
Notices
Reply
(#1 (permalink))
Old
COramprat's Avatar
I suck at attending the CWS.
My CarDomain Profile
97 Expedition - 06-17-07, 09:59 AM
Took a little trip this week and when I gave my Expy some gas to pass, the RPM's would run up like it had dropped into 3rd but would slow like I had a tranny slipping. With the cruise on the engine would jump from 2 grand to 3 on an incline but would actually slow speed wise. I'd have to disengage the cruise and just hold steady pedal to keep it at an agreeable speed and slowly get it up to the speed limit again . Getting on an on-ramp was like pedaling a bike in a head wind. Just had to take about twice the normal distance to get up to 70 since it would not accelerate at all at WOT and was very sluggish at 3/4.
Moderate acceleration in town traffic it would do fine. Drops into lower gear and moves along OK...but when going past 3/4 it peters off. Also have two codes...PO171 and PO174. Not sure if these are related to the problem.
Rick-Moderator Extraordinaire-4.6 Tech/Talk and the BHR.
96 Crystal White GT Coupe
* Comp 262H Cams *Trickflow Plenum *FRPP 70mm TB *PI Intake *Screamin' Demon Coils *Mac Fenderwell CAI *SCT 4 Bank Chip *Mac Prochamber *FRPP Aluminum Driveshaft *UPR FW adjuster and Tri hook quadrant *FRPP 4:10's *Steeda Tri Ax *Spec Stage 1 *Steeda Sport Springs *Tokico Shocks & Struts *Mach 1 Wheels
*240HP 273TQ
*13.827 @ 103.02...1.935 60' w/"crappy" NPI heads
My Garage
Get On It Racing
(#2 (permalink))
Old
timeless2's Avatar
My turn.
06-17-07, 01:55 PM
This might help.
Or this.
Or maybe this.
Tim
2010 Ford Mustang | MagnaFlow Exhaust | Toy Reviews & Recalls
Life is not about what you take; it is what you leave behind.
(#3 (permalink))
Old
COramprat's Avatar
06-17-07, 05:09 PM
Yea...I've found the post on why I may be getting the codes but it doesn't seem related to the drivaibility issues.
*240HP 273TQ
My Garage
Get On It Racing
(#4 (permalink))
Old
Darkwriter77's Avatar
Resident Ranting Negative Nancy
06-18-07, 08:34 PM
A lot of OBD-II scanners won't pull the transmission codes. You'll have to either find a buddy with one of those Snap-On scanners, rent/buy a high-end OBD-II scanner that specifically lists code-scanning capability for transmission codes, or have a dealership pull the codes for ya'.
It could be something as minor as a sensor of some kind throwing off the tranny, since most new automatics are electronically controlled - hell, even a bad plug wire can screw with your shifts, sometimes (it did on the 4.6L Crown Vic, Cougar, and T-Bird that I've owned) - but it might also be something more severe.
Is your "O/D off" light blinking? If so, that's an indication that you've got stored tranny trouble codes.
FOR MASOCHISTIC PLEASURE: 1984 Mustang LX 5.0 hatch ("The Black Pearl") - AOD w/shift kit, 84k miles, CFI, single 2.25" exhaust, and nothing else ... YARRRR!
FOR EVERDAY BUSINESS: 1986 GMC S15 ("Stinky") - a bajillion miles, x-cab, 5-speed, 2.8L, 2WD.
(#5 (permalink))
Old
COramprat's Avatar
06-18-07, 10:58 PM
No other indications other than the two check engine code. I reset them just ot see if they come back. So far nothing...
Someone suggested a clogged cat. That may explain the codes but I'm not sure if the drivability issues could be related. I do have some hesitation but I attributed it to whatever is causing the power drop.
*240HP 273TQ
My Garage
Get On It Racing
(#6 (permalink))
Old
svttech76's Avatar
SuperMod
it doe snot
06-19-07, 01:07 PM
p0171 and p0174 are lean codes. first things to check for with your symptoms would be a fuel pressure drop or a misfire.. ( misfires can lead to a lean code because the 02 sensors pick up the unburned oxygen and assume that the mixture is lean)
Mike
Ford master service tech
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
