Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page 4.6 Expedition high mileage
Reply
(#1 (permalink))
Old
4.6 Expedition high mileage - 08-08-07, 02:37 PM
I am looking at an expedition with a 4.6 engine. It has 139,000 miles on it. What are some of the problems these engines have when they get up there in miles? What should I look for? Thanks for the help.
(#2 (permalink))
Old
BurningRubber's Avatar
Official Member
08-08-07, 04:07 PM
They are generally long lasting engines. Check to see if any smoke is coming out of the exhaust, ticks, knocks, also check the oil level and see if its full.
2000 GT 5 speed Spring Feature: #? of 3,091 produced.
K&N FIPK. RPM ported plenum & PP 75mm TB. UPR offroad X. Mac Flowpath Catback. Diablosport Predator. Lowered. MGW short throw. Mach 1 grille delete. 4.10's.
New 1/4: 13.92 @ 100.17 with issues.
New 1/8th: 8.98 @ 78.70, same run as above.
(#3 (permalink))
Old
mustanggt3685's Avatar
Official Member
08-08-07, 04:55 PM
+1; that's the story I hear about them. I've seen guys on here with motors around 200K and no issue what so ever. Long as you take care of it, the 4.6 is bullet proof.
-Kevin
New wheels- Manual 2004 Mach 1 (DOB: 11/2003)
Torch Red: 1 of 1,259 (7,182 total)
BBK Off-Road X Pipe
(#4 (permalink))
Old
Official Member
08-08-07, 06:48 PM
I have a 99 Expedition and now have about 160k + miles on it. No break downs yet.
_____________________________________________
2004 GT. Mac OR/H, B&M Shifter, K&N
4.10's gears
(#5 (permalink))
Old
5.0's 4 ever's Avatar
The #1 Stunna
08-08-07, 07:00 PM
Some of them have problems with the passenger headgasket leaking oil, besides that its the usual wear and tear of any vehicle.
www.realstreetperformance.com
1996 Mystic Cobra built for turbo boost
Boss 330 Forged 283ci, 03 Heads, 99 Intake, Viper T56, etc...
2007 Lexus IS 250 daily driver
SOLD
88 5.0 LX Vert 434rwhp/408rwtq @10psi
91 5.0 LX Hatch
(#6 (permalink))
Old
Superhereaux's Avatar
chicks make me feel inadequate
08-08-07, 07:02 PM
take a small flashlight next time you go take a look at it. remove the oil cap and take a peek inside. it should be a light shade of brown, no black sludge. high oil change intervals will cause sludge that will hurt any engine no matter how bullitt-proof it is
check the ATF fluid, if it's the original fluid it will be brown with a slight hint of red (use a white paper towel or napkin). if it smells burnt or looks like strawberry milk don't buy it.
drive it and check for the obvious, smoke, knocks, wierd noises, etc. Ford trucks and modular engines in general are usually very reliable from what people who have owned them have told me
(#7 (permalink))
Old
Darkwriter77's Avatar
Resident Ranting Negative Nancy
08-08-07, 10:14 PM
Most of the earlier (pre-'99) 4.6's were prone to valve guide seals hardening and leaking above 100k miles, or with general age. If you get a puff of blue smoke when you first start it, or if you sit at idle for awhile and then take off (or go WOT after cruising granny-like for awhile), that's usually an early indicator of this. It's not a terribly catastrohpic sort of thing, but it will cause you to go through a bit of oil over time, fouls out your plugs, and will carbon up your EGR passages; you can get away with running thicker oil, changing plugs more often, and cleaning your passages more frequently, but ultimately you'll wind up having to replace those seals, and it's NOT a fun project. Expect to spend around $600 or so to pay a mechanic to do it, or waste a whole weekend farting around with it, if you try it alone - also helps to have a compressor and fitting to keep the valves from dropping.
Also, if it has a plastic intake manifold, see if they're already replaced it with the updated design manifold that has the aluminum crossover. The stock plastic ones were notorious for cracking and spewing coolant without warning, until Ford came up with the revised intake. (Fleet vehicles were covered under the recall, but it may have already expired by now.) A new intake will run you around $250, plus misc. little stuff.
Otherwise, as mentioned above, the 4.6 is pretty much a bulletproof motor. I hate letting go of my 4.6 T-Bird tomorrow morning, as it's a helluva solid motor, but my budget can only afford gas for one V8 car at a time...
1984 Mustang LX 5.0 hatch, AKA "The Black Pearl" - AOD w/shift kit, 84k miles, CFI - SLOW-ARSED WEEKEND "TOY."
1986 GMC S15, AKA "Stinky" - a bajillion miles, x-cab, 5-speed, 2.8L, 2WD - SLOW-ARSED DAILY BEATER.
RULE #1: The human race, as a whole, is a mass of stupid, selfish, arrogant buttholes.
(#8 (permalink))
Old
COramprat's Avatar
I suck at attending the CWS.
My CarDomain Profile
08-08-07, 11:44 PM
Quote:
Expys dont have a plastic intake. It't all aluminum.
I have a 97 with over 212K miles. Still runs well although it uses oil. Other than a broken shifter cable I haven't have a bit of trouble.
Rick-Moderator Extraordinaire-4.6 Tech/Talk and the BHR.
96 Crystal White GT Coupe
* Comp 262H Cams *Trickflow Plenum *FRPP 70mm TB *PI Intake *Screamin' Demon Coils *Mac Fenderwell CAI *SCT 4 Bank Chip *Mac Prochamber *FRPP Aluminum Driveshaft *UPR FW adjuster and Tri hook quadrant *FRPP 4:10's *Steeda Tri Ax *Spec Stage 1 *Steeda Sport Springs *Tokico Shocks & Struts *Mach 1 Wheels
*240HP 273TQ
*13.827 @ 103.02...1.935 60' w/"crappy" NPI heads
My Garage
Get On It Racing
(#9 (permalink))
Old
08-09-07, 12:56 AM
Ah. Just assumed that they did, since the Crown Vic and Mustang 4.6's had the plastic intakes.
(#10 (permalink))
Old
08-09-07, 01:06 PM
Thanks for all of the info. The truck had been wrecked on the drivers side door. The paint on the drivers side and passengers side doors were orange peeled. Also, you could turn the steering wheel about 5 inches either way before the wheels would turn. The engine ran good though. I am going to have to pass. It is not worth trading my F150 for it. Thanks again.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
