Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page new dd ..help with timing
Notices
Reply
(#1 (permalink))
Old
blckstng96's Avatar
Official Member
new dd ..help with timing - 09-12-07, 09:11 AM
i got a new DD its a 93 honda civic lx 15 non vtec 5spd. picked up for next to nothing and put a new distributor in it but i have no idea how to time one of these things,anyone here have a clue? i see no marks on the balancer or anything and i dont know what factory timing is set to either.any help is appreciated.thanks
96gt-MMR 5.0 stroker,fox lake stage 2+ heads,vt stage 2 cams.4:10s & eaton posi,mac lts and catback,vrs x-pipe,upr tubular front end kit,upr bumpsteer,03 cobra seats,black fr500s and too much other stuff to list
88 lx 5.0 hatch-victor jr,edelbrock 600 carb,pypes x-pipe,flowmasters,5lug,98 front brakes,98 gt wheels,456 gears
(#2 (permalink))
Old
85ragtop's Avatar
Deputy Dawg
Man woods surround my office.
09-12-07, 09:20 AM
You may get more help in here.
Nick
5.0 MOD
Quote:
Originally Posted by DMAN302
ahhh...the sarcasm...the stabbing of the back...God bless stangnet.
Quote:
Originally Posted by srothfuss View Post
I thought of a great reply about "feeling fast" but I deceided that I didn't want the gingerbread man to catch me with any type of ban hammer....
baby
(#3 (permalink))
Old
ninety15.0's Avatar
Official Member
09-12-07, 09:22 AM
I dont think you time those cars with the balancer...isnt it done with the cam gears? I may be mistaken but OHC engines are timed at cam gears, which means i think you need to pull the cam cover. You might try a honda forum...may have better luck there.
91 Red Gt 5 spd. Balanced 306, SRP frgd pistons 9.8:1, milled gt-40s w/ 3-angle, expl int, steeda #18, Pro magnum 1.6 rockers, 65mm tb & EGR, 24# inj. Pro-m 75mmMAF, K&N, BBK LTs, O/R H pipe, 40 series flows. PRO 5.0 shifter, AFPR, 255lph pump, 3.73's, spec stage 2, FWA/Quad, crane fireball coil, U/D pullies, steeda springs, kyb shocks/struts, MM C/C plates, Energy end links, FL SFC's, custom 4 pt cage, EBC slotted rotors and pads, 3G alt, PMGR starter, AL radiator, smog del....etc
(#4 (permalink))
Old
Darkwriter77's Avatar
Resident Ranting Negative Nancy
09-12-07, 09:42 PM
If it's anything like the 1.5L I had in my '87 CRX Si, there's not a whole lot of timing adjustment to be done on these things. Basically you need to pull the plastic timing belt cover off and rotate the crank around manually until the cam gear timing mark (an engraved/painted dot) lines up with the mark on the cylinder head, and ditto for the mark on the crank and engine block. If they're not off, then either the timing belt was improperly installed or the timing belt tensioner is getting weak enough that it allowed the belt to slip a notch ... but Hondas are usually interference engines, meaning that if the timing is off, you'll be banging valves against pistons and creating all kinds of a mess in there.
Honestly not sure if those motors allow for any real kind of timing adjustment at all or not, but if there's any to be had, I'd imagine it would be done by turning the dizzy ... although how, exactly, one goes about that, I dunno. IIRC, they're held into place pretty solid by a two- or three-bolt mount and don't really allow for any rotation like on a Ford or Chevy V8...
Now as for VALVE adjustment, that's a whole different deal. Older Hondas especially need to have their valvetrain adjusted every so many thousand miles. I remember reading that it was recommended every 15k, but I'd say more like 50k ... about the same time you change the timing belt, basically.
FOR MASOCHISTIC PLEASURE: 1984 Mustang LX 5.0 hatch ("The Black Pearl") - AOD w/shift kit, 84k miles, CFI, single 2.25" exhaust, and nothing else ... YARRRR!
FOR EVERDAY BUSINESS: 1986 GMC S15 ("Stinky") - a bajillion miles, x-cab, 5-speed, 2.8L, 2WD.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
