09-22-07, 08:55 AM
If your going carb, you need the complete engine, and swap headers, oil pan, and motor mounts, as well as a hood. You will also need a trans.
If your going EFI, you will need to convert a carb intake for injectors, and get a elbow to be able to mount the TB, as well as modifying a late model 460 dizzy to accept the 86-93 TFI module.
91 Vert
86 Coupe
93 Coupe
2.3 liters of FURY!
QA1 Tubular K member, control arms, coil overs & struts, Steeda CC, UPR UCA & LCA, eibach drag launch springs, 4.3:1, 33 spine, full spool, c clip elims, TFS girdle. 5 lug conversion, 3.5" & 10" Prostars w/ Nitto 275/50/15 drag radials.
