Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page '86 Tempo troubles
Reply
(#1 (permalink))
Old
Edster's Avatar
'86 Tempo troubles - 11-29-07, 05:07 AM
My '86 Tempo cuts out when running. I could be at highway speeds and it quits. If I wait a minute or two it will start right up. It also will cut out at a traffic light or when running at low speed as well. As long as I give it a minute or two before trying to start the engine it will start right up and run down the road a few minutes then quit. I'm wondering if it is an ignition or fuel problem. The car was taken to a mechanic who had the car for about a week and he stated the car gave him no troubles. He supposedly checked it out and could find nothing wrong. I hope someone has an answer to my problem.
(#2 (permalink))
Old
timeless2's Avatar
My turn.
11-29-07, 07:37 AM
Sounds like either a fuel pump or fuel filter issue. She's starving, it sounds like.
Check the leads and wiring headed to the fuel pump to see if there is any wire exposed or major corrosion issues, as your car is over 20 years old.
This is my hunch. I'm no ASE certified tech by any means.
Tim
2010 Ford Mustang | MagnaFlow Exhaust | Toy Reviews & Recalls
Life is not about what you take; it is what you leave behind.
(#3 (permalink))
Old
MrXCESSIVESPEED's Avatar
Official Member
11-29-07, 08:59 AM
I agree with the Fuel Pump...I had an 87 Tempo and it exhibited similar symptoms ..then one day it died and would not start. I noticed the pump was not priming when the key was turned. I had a friend beat on the gas tank and the car started. Replaced the pump and never had a problem again.
(#4 (permalink))
Old
Edster's Avatar
11-29-07, 10:58 AM
I'll check the leads out and see if it is a bad connection.
(#5 (permalink))
Old
greensvt21's Avatar
Official Member
11-29-07, 07:57 PM
youy could have 2 issues, i have seen crazy things happen with both fuel and electrical. sometimes older fuel pumps will over heat and cut out or drop fuel pressure but at the same time I have seen ignition coils heat up and loose spark. I would run a fuel pressure test anyway to see what condition the pump is in(if it's on the low side) and replace the fuel filter has it's cheap to do, also some pumps have a small filter screen or sock on them that can get clogged over time to. best of luck.
1991 mustang gt, white, 5.0, 5spd, 3:73's, some motor mods, suspension mods, interior mods, modifcations to my wallet and still a work in progress.
(#6 (permalink))
Old
Darkwriter77's Avatar
Resident Ranting Negative Nancy
11-30-07, 06:52 PM
+1 on the fuel pressure check.
The fact that the car not wanting to restart until it cools makes me think it's something ignition-related, but I would still lean towards it being a fuel pump, based on everything else.
Pretty much all in-tank fuel pumps have the "sock" filter, really. The thing is, if you're going to go through all the trouble of dropping the tank to change the thing out, you may as well replace the pump while you're at it, anyhow. So, check the fuel pressure first, and if it's not kosher, plan on splurging for a new fuel pump and sock.
1984 Mustang LX 5.0 hatch, AKA "The Black Pearl" - AOD w/shift kit, 84k miles, CFI - SLOW-ARSED WEEKEND "TOY."
1986 GMC S15, AKA "Stinky" - a bajillion miles, x-cab, 5-speed, 2.8L, 2WD - SLOW-ARSED DAILY BEATER.
RULE #1: The human race, as a whole, is a mass of stupid, selfish, arrogant buttholes.
(#7 (permalink))
Old
Edster's Avatar
12-09-07, 09:35 AM
Well I fixed the Tempo yesterday. It turned out it was the ignition. Auto Zone will test it for free. It passed every test except for the "break current" test. While I was at it I replaced the cap and rotor. So far so good.
Thanks for everyones help.
(#8 (permalink))
Old
greensvt21's Avatar
Official Member
12-09-07, 10:26 AM
what part of the ignition, the actual switch itself? just curious. glad you got it fixed though .
(#9 (permalink))
Old
Edster's Avatar
01-27-08, 08:09 AM
The module that sits on the side of the distributor.
(#10 (permalink))
Old
tr7driver's Avatar
Official Member
Glad to hear you got it fixed - 01-28-08, 01:30 PM
One trick for these types of cut-out is to watch your tach, if it is an electrical issue, the tach will drop like a rock when it cuts out, a fuel issue will usually show a slow drop to zero.
I hope you got your money back from your mechanic.
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
