Go Back   Mustang Forums at StangNet > General Automotive Forums > Other Auto Tech
Reload this Page My ranger keeps overheating!!!
Reply
(#1 (permalink))
Old
Official Member
My ranger keeps overheating!!! - 12-07-07, 01:43 PM
Hey guys i know its not a mustang but i figured since its a ford you guys may be able to help me out.
Anyway i have a very weird overheating problem with my 2001 Ranger 3.0 liter.
It only happens about one time per one tank of gas, so 95% of the time it runs fine. Whats happens is, it gets to operating temp and stays there for a while, then out of nowhere my heat blows cold. The temp guage will then drop a bit and seconds later it skyrockets up to the point where it overheats. By the time i try and pull over to shut it off, the temp drops back down to normal.
I have replaced the thermostat and radiator cap thinking it might be the problem but no luck. I have also bled the system of air and it has fresh coolant in it. All of the hoses appear to be fine also. Something weird i have noticed also is that the overflow tank does not have a vent, so the whole cooling system is not vented.
I need your guys help to figure this out!!! It has made me late to class a few times and is getting very irratating!!
Thanks!!!
85 GN- stock turbo, alcohol injected, 18#'s of Boost---SOLD
89' lx vert- AFR 165's, Fcam, Cobra Intake, 24# injectors,1.6 RR, AOD, Edge 3200 Nonlock, BBK Shorties, Flows, 3:55's, 100 Shot Zex
01 Ranger- supercab, 4x4, Auto, K&N
(#2 (permalink))
Old
HISSIN50's Avatar
"How long do you think it'll take me to get any help?" --Richard Harris
12-08-07, 01:34 AM
What temps do you read? If you are using a stock gauge, you need a mechanical gauge (even if only temporarily installed) to see what's really going on. Huge temp fluctuations in almost no time (especially if going way up and then way down) are likely a gauge issue.
Do you ever hear coolant boiling or note the overflow fuller than normal?
Is the overflow bottle cap vented? Some tanks dont have a hole at the top but the cap itself has louvers/vents.
Anyhoo, I'd get a 15 dollar mech gauge on there so you can really see what it's doing.
Good luck.
Wanted: '87-'95 T5 and/or AODE to T5 swap parts for a '94 GT
(#3 (permalink))
Old
RUNINAGT's Avatar
Official Member
12-08-07, 05:48 AM
The gauge being bad would not make the heat stop working??
Maybe a possible blockage in the heater core? Or heater Coil like some customers call it
Does the engine light come on, if so have it scanned to see if there are any codes stored, pertaining to coolant temp issues.
AUG 2005. WAS FOUND TOTALLY STOCK WITH ONLY 16,000 MILES.
ADDED
- FLOWMASTERS
- O/R H-PIPE
- U/DRIVE PULLEYS
- ADVANCED TIMING TO 14
- REMOVED SILENCER
- COBRA WING
- 17" 4-LUG SALEEN WHEELS W/BFG'S
245/45z17's ON FRONT 275/40z17's ON REAR
BEST 1/8TH TIME 9.3@ 75MPH. BEFORE H-PIPE. PROBABLY GONNA STAY THE SAME WITH IT.
OK AFTER H-PIPE 9.26 @ 77.14 MAY OF BEEN THE PIPE----MAY OF NOT
Aug 21 2007 ADDED MAC SHORTY'S
(#4 (permalink))
Old
Official Member
12-08-07, 05:01 PM
It is not a guage problem because when it reads hot it actually will puke coolant out of the overflow. I do have a vented cap also. I can hear the coolant bubbling up in the overflow, after i shut the truck off from normal driving. And the check guage light will pop on when it gets hot, and then go off when it cools back down so i couldnt do a code scan without the check guage light on right?
Ive heard that it could be an air pocket in the system, but ive bled the system already and it still happens.
Anyways, thanks you guys for the help!
(#5 (permalink))
Old
Roland69's Avatar
Sergeant Tangnet
12-09-07, 05:39 PM
air in your system I would think.
Celebrating our 4 year anniversary as Rulers of 5.0Talk.
MY 88 GT
MY 92 Z71
88 GT 5speed
88 4cyl Coupe auto
97 Ranger 3.0L 5speed stepside
92 Z71 5.7L stepside
88 4cyl hatch (sold)
95 V6 (GT clone) auto (sold)
Sound Clip Of My Exhaust
(#6 (permalink))
Old
Roland69's Avatar
Sergeant Tangnet
12-09-07, 05:44 PM
park somewhere so the front is high so your rad cap is higher then the rest of the system. Maby put the front on ramps. Run the truck till it gets hot with the rad cap off. and make sure the heat is on high (I always have it on the floor setting) the coolant level should drop once the stat opens so be standing by with coolant to pour in when that hapens. I use a rad funnel. Look into getting one of those if you work on cars now and then they are the best thing EVER
If you want to speed this up you can stick a long screwdriver or stick inbetween the gas peddal and the seat and have the RPM's around 1800
MY 88 GT
MY 92 Z71
88 GT 5speed
88 4cyl Coupe auto
(#7 (permalink))
Old
85ragtop's Avatar
Deputy Dawg
Man woods surround my office.
12-09-07, 06:19 PM
Moved to other auto tech.
Nick
5.0 MOD
Quote:
Originally Posted by DMAN302
ahhh...the sarcasm...the stabbing of the back...God bless stangnet.
Quote:
Originally Posted by srothfuss View Post
I thought of a great reply about "feeling fast" but I deceided that I didn't want the gingerbread man to catch me with any type of ban hammer....
baby
(#8 (permalink))
Old
Banned
12-26-07, 10:09 PM
Reply
Bookmarks
Thread Tools
Rate This Thread:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
