Go Back   Mustang Forums at StangNet > Mustang Forums > 5.0 Mustang > Fox Engine Swaparoo
Reload this Page SBC in fox
Reply
(#1 (permalink))
Old
bynummustang's Avatar
Official Member
SBC in fox - 06-10-08, 04:45 PM
Flame away.
I'm wondering what would be needed to put a Chevy 350 in a fox. I'm only entertaining the idea of doing this because I can build a 350 much cheaper than I can do a SBF. I'm on a big budget, and I can get the motor built, I just need to know what I would need to put it in my fox.
I'm thinking that I would need:
New motor mounts
K-member
Double sump oil pan
bellhousing from an old Camaro
Thanks,
Jordan
(#2 (permalink))
Old
Vipersix's Avatar
06-10-08, 10:34 PM
Well, you've got the right idea. I'm not sure if anybody manufactures a k-member which works so you may need to do a bit of cutting and welding yourself. The motor mounts and oil pan are a given as they are part of the engine. The bellhousing obviously would need to mate to whatever xmsn you are using. The headers would need to be custom most likely. The biggest headache you would get by far is electronics. Even if the connectors are shaped in the same manner, Ford and Chevy use different sensors for the most part which means they have dissimilar resistances and reference voltages. Short of getting some MAJOR computer work done, you would probably need an entire new engine management system. And, thus, offset the cheaper cost of a Chevy!
'94 Mustang GT Conv.
Body: 8-Point Cage, Custom 9” w/Detroit Locker, Granatelli Coil-Overs & A-Arms
Engine: 351W bored & stroked (395ci), Low-Compression Alum. Probe Pistons, Eagle Rods & Forged Crank, AFR 205cc, 6-71 blower, Enderle Bugcatcher Intake, BDS 16-Nozzle EFI Plate, MSD system, Custom 3" Headers, Custom Side-Exhaust, Aeromotive Fuel System, MegaSquirt EFI System, Meziere Electric Water Pump
Other Goodies: TKO 600, FMS Alum. Driveshaft, 4-Core Alum. Radiator
(#3 (permalink))
Old
Official Member
06-11-08, 07:25 AM
Ah, the only connectors I'll use are for the gauges, and ignition. Part of the reason I'm going to a SBC is for carb power too. So that EFI stuff is coming out and staying out.
Do you know where I can get a double sump oil pan for the 350? Will the stock 350 motor mounts work? Or custom too?
(#4 (permalink))
Old
Vipersix's Avatar
06-11-08, 07:29 AM
I would guess Jegs or Summit would have an oil pan sufficient for your application. I would first experiment with the K-member so you can get some accurate measurements for the pan. That way you only have to buy one pan and not have to deal with trial and error fitting. The stock 350 motor mounts should work just fine depending on the K-member. I really foresee that as you biggest headache initially.
(#5 (permalink))
Old
Official Member
06-11-08, 10:39 AM
It'd be nice if I could get a 350 bare block and motor mounts, and place it down, see what happens. I'll keep searching around for more info. I know many of people have down it, but I'm not able to find any write-ups.
(#6 (permalink))
Old
06-12-08, 12:37 PM
AJE has a k-member with poly engine mounts to mount the engine. We also have a trans crossmember to mount the PG or Turbo400. Lemons Header or Kooks Headers are building headers for this application.
(#7 (permalink))
Old
Official Member
06-14-08, 05:19 PM
1st thing you need to do is go to the barber get a Mullet cut. Next go grab a 18 pack of PBR. Go out to the garage and blast some poison on your radio. Go knock on the neigbors door and ask if you can buy that rusted 85 IROC Z in thier back yard and put that small block chevy idea in the camaro. J/K but seems like its more expensive to do the chevy swap. I dont find fords to be that much more expensive than a sbc especialy when goin carbed...SBF gotta be the cheaper than mopar or BOP,AMC engines? Why not keep the ford? Ive had many chevys and used to think the same but if you at least got a paper route job Im sure you can build a SBF
(#8 (permalink))
Old
Official Member
06-16-08, 12:21 PM
Quote:
Chevy blocks are stronger, and I can find core blocks cheaper here. If I can find a 351 block near me that I can build up to 13:1 comp. for the price of the chevy blocks I'll do it.
(#9 (permalink))
Old
Vipersix's Avatar
06-22-08, 11:44 AM
I don't know about stronger but they are definitely cheaper. There is something to be said about the genius behind making cookie cutter engines like Chevy did. Smart engineering if you ask me.
(#10 (permalink))
Old
RWDtech's Avatar
06-22-08, 11:50 PM
what a dream mustang!
interested in notchback foxes
SOLD
my cardomain
(#11 (permalink))
Old
82CapriRS's Avatar
09-02-08, 01:16 PM
+1 why have a ford when your gonna put a chevy motor in it. i understand your point but it doesnt mean it should be ok. why not sell the mustang an get a chevette an put your 350 chevy in there. sorry but when i see people puttin chevy motors in a fox or even a ford in general it just gets to me. if its about cost then sellin your fox an buyin the chevette will help you there too. im with juggalo95 on this one, after all the parts you buy to swap the chevy motor in you could have just done a sbf..
82 Capri RS 5speed(non bubbleback)
- SOLD
90 LX- edelbrock intake an 600 carb, msd ignition coil cap an rotor, frpp unequal length stainless headers, off road h pipe, an mac catback, holley blue pump an regulator, eibach sportlines, MM strut tower brace, 3:55s, pro 5.0 short throw. and a beat up stock clutch.
14.1@101.13 2.19 60 ft
(#12 (permalink))
Old
Gearbanger 101's Avatar
SuperMod
Canadian Colossus
09-02-08, 01:17 PM
Quote:
An IQ below 80 would be my guess.
~Brian~
1996 Mercury Cougar XR7
410HP/465TQ
My....................Cat....................Eats. ..................Dogs!!!!!
(#13 (permalink))
Old
Official Member
09-02-08, 03:13 PM
Ignore the naysayers and do what you want, however the money issue is a moot point as there are tons of both roller 351 blocks, early beefier blocks, Clevelands, and sub 2000 dollar aftermarkets if you are really going wild, any of those can be built to have enough horsepower to make you change your shorts. If you ever have been in a Fox with more that 500 rwhp, you know what I mean...
Matt
p.s. 460s are dirt cheap and are comfortable with 1000 hp
(#14 (permalink))
Old
Today, 09:23 AM
A double sump pan would not be needed for a Chevy motor. The double sump is needed for the 5.0 because the oil pump is mounted in the front of the motor. The front sump is for pump clearance. On a sbc the pump is in the back so only one sump is required.
Reply
Bookmarks
Thread Tools
Display Modes
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
