StangNet's Project 67
Model
1967 Ford Mustang Fastback
Engine
428 CobraJet
Suspension
RRS Stage III
Exhaust
Catback: Magnaflow Headers: TBD
Paint
1964 Ford Guardsman Blue
Project sponsored by
CJ Pony Parts, TMI Products, Classic...
You do not have permission to view the full content of this resource. Log in or register now.
Reactions: 6 users
Author
MRaburn
First release
Last update
Rating
5.00 star(s) 9 ratings
Latest updates
  1. 428 CJ FE Running on the Engine Stand
    The engine is up and running for our 67 Project. The engine will be EFI once installed in the...
  2. Edelbrock E-Street EFI System
    We have EFI! We will be running the Edelbrock E-Street EFI system for our 428 FE setup in the...
  3. She is a rolling chassis again!
    After the cutting in the paint of the Guardsman Blue, our Fastback project has gotten her 'roll...
  4. Paint! Cut in the jams, engine bay and underbody
    Today we were finally able to get some Guardsman Blue on the 67. Pictures do NOT do this color...
  5. Engine Update
    The 428 CJ is coming along. This is an all Iron (Fe) setup. We have an original 69 428 block...
  6. Body In First Primer
    Slow and steady! First coat of primer is on. Only 2 more blocking's to go. :) We will then...
  7. Primer Going On
    It's been a bit slow but the Holidays and colder weather has slowed up down. The initial...
  8. First Blocking Done - Reface done
    Car and parts have been blocked down for the first time. It will be blocked 2 more times after...
  9. Original 428 Cobra Jet Crank
    Yep... have had this for several years stored in the corner, had always thought it was a 390...
  10. Color is Changin, Reface is on to start blocking #1
    We finished getting all the gaps the way we wanted. Fitment has been done and now we have taken...
  11. Working the Hood and Trunk area
    We decided not to run signal lights in the cowl of the hood so we smoothed those off and got the...
  12. Removing the Cowl Vents
    We are going with aftermarket A/C setup so with keeping the smooth look we opted to block out...
  13. CJ Pony Parts Smooth Lower C panels
    We opted to keep the lines on this car all smooth. Having the inverted upper sail panels, we...
  14. Shock Towers Notched
    Making room for the 428FE! Project sponsored by CJ Pony Parts
  15. Working the hood gaps
    The hood is fitting nicely and we have got the gaps like we want them. Working the hood and...
  16. Getting the Door gaps right
    No easy task! Patience and work! Project sponsored by CJ Pony Parts
  17. Headlight Buckets Mounted
    Finally worked the headlights in. They are mounted to the fenders, not the front cover like a...
  18. Front Fascia Mounted
    Working the CDC front fascia in and getting the gaps and fitment right. Sponsored project...
  19. RRS Rear Brakes and RRS Watts 3-Link installed
    We installed the suspension into our project. We know it's early in the build but in order to...
  20. Body Works has begun on our Dynacorn Body
    We have installed the CDC upper C sail panels and have started installing and gapping the rear...
Latest reviews
This is one BA car build.
Gonna be sick, can't wait for the finished product.
